Valkyrie A360 AIO CPU Liquid Cooler Review: rendimiento y precio muy destacable para un kit ARGB
Mostrando página 2 de 4
Especificaciones del Valkyrie A360 AIO CPU Liquid Cooler
Foto del radiador
Compatibility
AMD AM5, AM4
Intel1851, 1700, 1200, 1151
CPU TDP300W
Warranty3 Years
Weight2450g
RGB  Connector3-Pin A-RGB Connector
Pump and Fan Power Connector4-Pin PWM Connector
Pump
Pump800-2400RPM ± 10% (PWM controlled)
Voltage12V
Pump Unit Dimensions84.14mm x 78.4mm x 53 mm
Tube Length425mm
Tube MaterialCIRR + EPDM
Tube Sleeving Corrugated Material Braided Sleeve
Radiator
Material Aluminium
Dimensions397 x 120 x 27 mm
Radiator Fans
Fan 3x Valkyrie A12 A-RGB
Speed 800 - 1800RPM ± 10%
Air Flow 69CFM / 117.23 m³/h
Static Pressure2.2 mmH₂O
Maximum noise level32.8 dBA (Max)
BearingRifle Bearing
Current0.2V
Voltage12V
Tags:Valkyrie, Refrigeración
