Ahead actualiza NeroLinux, que llega a la versión 3.0.2.1
9 de noviembre, 2007 |
Usuarios |
Comentarios: 3
Ahead sigue puliendo su versión de Nerolinux, que llega a la versión 3.0.2.1. Muchos errores corregidos y más estabilidad. Se puede probar descargando una versión de prueba desde este enlace: Disponible en versiones de 32 y 64 bits empaquetados en DEB y RPM.
Aquí la lista de cambios (Inglés).
New features:
  • The ''Properties'' dialog for files and folders now supports multiple selection
Feature updates
  • The new kernel pata_xxx SCSI emulation drivers are now fully supported, and the burn engine has been updated to use them correctly
  • The DVD ISO images burning process has been fixed. No weird speed or burn process that never ends should occur
  • Added some additional information to the preview widget in the ''Open compilation'' and ''Open Image'' dialog box. The user is now able to get some properties of the selected compilation/image
  • When loading a compilation with non-existing items, a warning dialog box will inform the user about it
  • Added some more pre-burn checks:o for data discs, mode 1 is selected for any medium type other than CDo for CD EXTRA compilation: at least one audio track should be present
  • The item duplication now works correctly and does not delete the original item anymore
  • When ripping an audio track, the ''/'' character is automatically replaced by ''_'' for the output file name
  • The ''Disc Info'' dialog output for DVD-RW is now fixed
  • The Japanese manual has been updated
  • The date chooser widget now contains ''Ok'' and ''Cancel'' buttons to be a little bit more user-friendly
  • The splashscreen is now correctly centered with all window managers
  • Some keyboard accelerators have been added to the ''Encode Files'' dialog
Patches:
  • The ''Data'' button of the Mixed-Mode/CD EXTRA compilation editor is now correctly working
  • Fully erasing a disc on an IDE internal device with new kernels is now working
  • The ''Eject the disc when the erase is complete'' option is now working correctly
  • Fixed a memory leak within the ''Erase Settings'' dialog
  • The direct connection to FreeDB servers now works like a charm
  • The re-sampling of audio file when creating audio CD out of it is now working properly
  • The ''Properties'' dialog for files and folders is now counting the directory items and size correctly
  • The ''Info'' tab of the mixed-mode and CD EXTRA compilations in the ''New Compilation'' dialog now show the correct size
  • The data part of mixed-mode and CD EXTRA compilations can now be correctly re-burned
  • Avoid application crash when loading a compilation with non-existing directory references
Gracias a CoSiMo por redactar esta noticia.
Tags: Nero, Linux
Ver comentarios: 3
