MSI MPG CoreLiquid P22 360 Review: una AIO de 360 mm con pantalla LCD, ARGB y gran rendimiento
Mostrando página 2 de 4
Especificaciones del MSI MPG CoreLiquid P22 360
Foto del kit de refrigeración líquida
Pump Speed: 3400±340 RPM
Load Current: 0.21±0.042 A
Power Consumption: 2.52±0.504 W
Life Expectancy: 40℃,50000 hours
Water Block Dimensions: 71.63 x 69.47 x 77.61 mm
Panel Size: 2.1
Panel Type: IPS
Panel Resolution: 540 x 540
RadiatorSize: 360 mm
Dimensions: 394 x 119.2 x 27.2 mm
Material: Aluminum
TubeLength: 390 mm
Material: EPDM+IIR
FanSize: 120 × 120 × 25 mm
Quantity: 3
Speed: 500~2000±200 RPM
Air Flow: 62.6 CFM
Air Pressure: 2.36 mm-H2O
Noise: 31.1 dBA
Bearing: Rifle Bearing
Life Expectancy: 40℃,40000 hours
Rated Current: 0.15±0.03 A (Set)
Power Consumption: 1.8±0.36 W (Set)
LED: ARGB GEN1
CompatibilityIntel: LGA 1700 / 1851
AMD: AM5 / AM4
Tags:MSI, Refrigeración
