be quiet! Light Loop IO LCD 360mm Review: una refrigeración líquida AIO con pantalla LCD, ARGB y un excelente rendimiento
Mostrando página 2 de 4
Especificaciones del be quiet! Light Loop IO LCD 360mm
Foto del radiador y el bloque
General data
ModelLIGHT LOOP IO LCD | 360mm
Color optionBlack
Dimensions radiator, incl. fan (H x W x D), (mm)397 x 120 x 52
Dimensions cooling block (H x W x D), (mm)63.8 x 61.9 x 54
Total weight (kg)1.6
Socket compatibility Intel1851 / 1700 / 1200 / 1151 / 1150 / 1155
Socket compatibility AMDAM5 / AM4
Noise level (dB(A)) at 50% / 75% /100% rpm17.2 / 29.1 / 36.8
Number of fans3
Lighting connectorIO connector
Tube length (mm)400
Refill port✓
Infographics
Pump specifications
Pump speed (rpm)2900
Pump adjustable (rpm)1500 - 2900
Pump connectorIO connector
Radiator specifications
Dimensions (L x W x H), (mm)397 x 120 x 27
Radiator material / finishAluminum
Base material / finishcopper / nickel plating
Fan specifications
Fan modelLight Wings LX 120mm PWM high-speed
Fan dimensions (mm)120 x 120 x 25
Speed at 100% PWM (rpm)2100
Ariflow at 100% PWM / 12V (CFM / m3/h)61.8 / 105.1
Air Pressure at 100% PWM / 12V (mm H2O)2.51
Bearing technologyRifle
Motor technology4-pole
Rated Voltage (V)12
Input current (A)0.17
Safety current (A)0.45
Input power (W)5.4
Connectorproprietary
Cable length (mm)20 / 100 + daisy chain
Lifespan (h / 25°C)60,000
Accessories
Thermal grease (Type)Included
Mounting setIntel, AMD
Adapter cablesARGB-PWM breakout
Bottle of coolant (ml)100
ARGB controller with SATA cable-
ARGB-PWM-Hub-
IO Controller✓
User manual languagesCN, DE, EN, ES, FR, JP, PL, RU, TW
Safety certifications
ApprovalsCE, UKCA,FCC
Environmental directives
RoHS✓
WEEE✓
Triman✓
Service
Warranty (Years)3
International hotline / free of charge✓ / DE, FR, US
Logistics data and RRP
Article numberBW032
EAN code4260052193228
Dimensions, package (L x W x H), (mm)448 x 205 x 137
Gross weight, package (kg)2.61
Pieces per packaging unit4
Dimensions, shipping box (L x W x H), (mm)470 x 298 x 445
Gross weight, shipping box (kg)11.54
RRP (€)229.90
Tags:be quiet!, Refrigeración
