Especificaciones de la Gigabyte Radeon RX 7900 GRE Gaming OC 16G
| Graphics Processing | Radeon™ RX 7900 GRE |
| Core Clock | Boost Clock* : up to 2391 MHz (Reference card: 2245 MHz) Game Clock* : up to 2052 MHz (Reference card: 1880 MHz) |
| Stream Processors | 5120 |
| Memory Clock | 18 Gbps |
| Memory Size | 16 GB |
| Memory Type | GDDR6 |
| Memory Bus | 256 bit |
| Card Bus | PCI-E 4.0 |
| Digital max resolution | 7680x4320 |
| Multi-view | 4 |
| Card size | L=302 W=130 H=56 mm |
| PCB Form | ATX |
| DirectX | 12 Ultimate |
| OpenGL | 4.6 |
| Recommended PSU | 700W |
| Power Connectors | 8 Pin*2 |
| Output | DisplayPort 2.1 *2 HDMI 2.1 *2 |
| Accessories | Quick guide |
| Note | * “Boost Clock” is the maximum frequency achievable on the GPU running a bursty workload. Boost clock achievability, frequency, and sustainability will vary based on several factors, including but not limited to: thermal conditions and variation in applications and workloads. * “Game Clock” is the expected GPU clock when running typical gaming applications, set to typical TGP (Total Graphics Power). Actual individual game clock results may vary. |
