ASUS ROG Strix SLC IV 360 ARGB LCD Review: AIO premium con gran estética, LCD y conectividad avanzada
Mostrando página 2 de 4
Especificaciones del ASUS ROG Strix SLC IV 360 ARGB LCD
Foto de la refrigeración líquida
Water block
Water block dimention: 123.2 x 99 x 91.7 mm
Block Material (CPU Plate): Copper
Radiator
Radiator Dimension: 397 x 125.8 x 27 mm
Radiator Material: Aluminum
Tube: Sleeved Rubber tube
Tube Length: 250 mm
Fan
Size: 3 x Fan Slots (120mm)
Dimension: 360 x 124 x 26.5 mm
Speed: 800 - 2500 RPM +/- 10%
Static Pressure: 4.36 mmH2O
Air Flow: 82.57 CFM
Noise: 35.78 dB(A)
Control Mode: PWM
Special features
Display: 5.08" Full Color IPS LCD
AURA Sync Support: Yes
Compatibility
AMD: AM5,AM4
Intel: LGA 1851, 1700
Package content
1 x CPU Liquid Cooler (pre-applied thermal compound)
1 x ROG Sticker
1 x Quick Start Guide
1 x Accessory Pack of Screws and Brackets
1 x Warranty Card
1 x 360 x 124 mm integrated fan (pre-installed)
1 x ASUS AIO Q-Connector Plug
1 x Cable plug (Pre-installed on cooler pump)
1 x Accessory
Warranty6 years
SoftwareASUS InfoHub
Tags:ASUS, Refrigeración
