| CPU | LGA1851 socket: Support for Intel Core Ultra Processors |
| Chipset | Intel Z890 Express Chipset |
| Memory | Support up to DDR5 9466+MT/s (OC) 4 x DDR5 DIMM slots, Dual Channel Max. Capacity 256 GB Support Non-ECC, Un-buffered, Clocked Unbuffered DIMM (CUDIMM) Supports Intel Extreme Memory Profile (XMP) memory module (The CPU and memory configuration may affect the supported memory types, data rate (speed), and number, please refer to "Memory Support List" on GIGABYTE website |
| Onboard Graphics | Integrated Graphics Processor-Intel HD Graphics support: -1 x USB 4 Type-C Support, supporting DisplayPort video output and a maximum resolution of 3840x2160@144 Hz *Support fot DisplayPort 2.1 version.
- 1 x DisplayPort, supporting a maximum resolution of 3840x2160@144 Hz *Support fot DisplayPort 2.1 version.
(Graphics specifications may vary on CPU support.) |
| Audio | Realtek® ALC1220 CODEC *The back panel line out jack supports DSD audio.
High Definition Audio 2/4/5.1/7.1-channel *You can change the functionality of an audio jack using the audio software. To configure 7.1-channel audio, access the auidio software for audio settings.
Support fot S/PDIF Out |
| LAN | Realtek 5GbE LAN chip (5 Gbps/2.5 Gbps/1 Gbps/100 Mbps) |
| Wireless Communication module | Intel Wi-Fi 7 BE200NGW - 802-11a, b, g, n, ac, ax, be, supporting 2.4/5/6 GHz carrier frequency bands - Bluetooth 5.4 - Support for 11be 320Hz wireless standar (Actual data rate may vary depending on environment and equipment.) * Wi-Fi 7 features requiere Windows 11 SV3 to function properly. (There is no support driver for Windows 10.) ** Wi-Fi 7 channels on 6 GHz band available depends on individual contry's regulations. *** Bluetooth version may change with updates. See the Wi-Fi chip vendor's website for details. |
| Expansion slots | CPU: - 1 x PCI Express x16 slot, supporting PCIe 5.0 and running at x16 (PCIEX16) *The PCIEX16 slot can only support a graphics card or an NVMe SSD. If only one graphics card is to be installes, be sure to install it in the PCIEX18 slot.
Chipset: - 2 x PCI Express x16 slots, supporting PCIe 4.0 and running at x4 (PCIEX4_1, PCIEX4_2) |
| Storage Interface | CPU: - 1 x M.2 connector (Socket 3, M key, type 25110/22110/2280 PCIe 5.0 x4/x2 SSD Ssupport) (M2A_CPU) - 1 x M.2 connector (Socket 3, M key, type 22110/2280 PCIe 4.0 x4/x2 SSD Ssupport) (M2B_CPU) Chipset: - 1 x M.2 connector (Socket 3, M key, type 22110/2280 PCIe 4.0 x4/x2 SSD Ssupport) (M2Q_SB) - 1 x M.2 connector (Socket 3, M key, type 22110/2280 SATA and PCIe 4.0 x4/x2 SSD Ssupport) (M2M_SB) - 4 x SATA 6GB/s connectors RAID 0, RAID 1, RAID 5, and RAID 10 support for NVMe SSD storage devices RAID 0, RAID 1, RAID 5, and RAID 10 support for SATA storage devices |
| USB | CPU: - 1 x USB4 Type-C port on the back panel Chipset: - 1 x USB 3.2 Gen 2 Type-A ports (red) on the back panel - 2 x USB 3.2 Gen 2 Type-A ports (red) on the back panel - 5 x USB 3.2 Gen 1 ports (3 ports on the back panel, 2 ports available through the internal USB header) Chipset+2 USB Hubs_ - 8 x USB 2-0/1.1 ports (4 ports on the back panel, 4 ports available through the universal USB headers) |
| Internal I/O Connectors | 1 x 24-pin ATX main power connector 2 x 8 pin ATX 12V power connectors 1 x CPU fan header 1 x CPU/water cooling pump header 2 x system fan headers 1 x system fan/water cooling pump header 3 x addresable RGB Gen2 strip headers 1 x RGB LED strip header 4 x M.2 Socket 3 connectors 4 x SATA 6Gb/s connectors 1 x front panel header 1 x front panel audio header 1 x USB Type-C headers, with USB 3.2 Gen 2 suppport 1 x USB 3.2 Gen 1 header 1 x USB 2.0/1.1 headers 2 x Thuderbolt add-in card connectors (For GIGABYTE Thunderbolt 5 add-in card only) 1 x Trusted Platform Module header (For the GC-TPM2.0 SPI V2 module only) 1 x reset jumper 1 x Clear CMOS jumper |
| Back Panel Connectors | 1 x power button 1 x reset button 1 x Q-Flash Plus button 1 x Clear CMOS button 1 x USB4 Type-C port (DisplayPort (Note)) 2 x USB 3.2 Gen 2 Type-A ports (red) 3 x USB 3.2 Gen ports 4 x USB 2.0/1.1 ports 2 x antenna connectors (2T2R) 1 x DisplayPort (Note) 1 x RJ-45 port 1 x optical S/PDIF Out connector 2 x audio jacks
(Note) Actual support may vary by CPU |
| I/O Controller | iTE I/O Controller Chip |
| H/W Monitoring | Voltage detection Temperature detection Fan speed detection Water cooling flow detection Fan fail warning Fan speed control *Whether the fun (pump) speed control function is supported will depend on the fan (pump) you install. |
| BIOS | 1 x 512 Mbit flash Use of license AMI UEFI BIOS PnP 1.0a, DMI 2.7, WfM 2.0, SM BIOS 2.7, ACPI 5.0 |
| Unique Features | Support fot GIGABYTE Control Center (GCC) *Available applications in GCC may vary by motherboard model. Supported functions of each application mat also vary depending on motherboard specifications
Support for Q-Flash Support for Q-Flash Plus Support for Smart Backup |
| Bundled Software | Norton Internet Security (OEM version) |
| Operating System | Support for Wuindows 11 64-bit |
| Form Factor | ATX Form Factor, 30.5cm x 24.4cm |
