GIGABYTE Radeon RX 9070 XT GAMING OC ICE 16G Review: potencia RDNA 4 para jugar a 1440p
Mostrando página 2 de 18
Especificaciones de la GIGABYTE AMD Radeon RX 9070 XT GAMING OC ICE 16G
Foto de la GPU
Graphics ProcessingRadeon RX 9070 XT
Core ClockBoost Clock* : up to 3060 MHz (Reference card: 2970 MHz)
Game Clock* : up to 2520 MHz (Reference card: 2400 MHz)
Stream Processors4096
Memory Clock20 Gbps
Memory Size16GB
Memory TypeGDDR6
Memory Bus256 bit
Card BusPCI-E 5.0
Digital max resolution7680 x 4320
Multi-view4
Card SizeL=288 W=132 H=56 mm
PCB FormATX
DirectXDirectX 12 API
OpenGL4.6
Recommended PSU850W
Power Connectores8 pin*3
OutputDisplayPort 2.1a x2
HDMI 2.1b x2
AccesoriesQuick Guide
Note* “Boost Clock” is the maximum frequency achievable on the GPU running a bursty workload. Boost clock achievability, frequency, and sustainability will vary based on several factors, including but not limited to: thermal conditions and variation in applications and workloads. GD-151
* “Game Clock” is the expected GPU clock when running typical gaming applications, set to typical TGP (Total Graphics Power). Actual individual game clock results may vary. GD-147
Tags:AMD, Tarjetas Gráficas, Radeon RDNA 4, Gigabyte
Ver comentarios (1)
  • Insta360 X5 Esencial Kit 8K
