MSI Modern MD272QXP Review: monitor ideal para productividad
Mostrando página 2 de 4
Especificaciones del MSI Modern MD272QXP
Foto del monitor
USB 2.0 Type A2
HDMI1
HDMI version2.0b
HDMI HDCP version2.3
DisplayPort1
DisplayPort version1.2a
USB Type C (DisplayPort Alternate)1
Power TypeExternal Adaptor 19V 5.79A
Adjustment (Tilt)-5° ~ 20°
Adjustment (Swivel)-30° ~ 30°
Headphone-out1
Adjustment (Height)0 ~ 110 mm
Adjustment (Pivot)-90° ~ 90°
Lock typeKensington Lock
VESA Mounting75x75mm
Speaker2
Frameless DesignYes
Weight (Net kg)5.85
Weight (Gross kg)8.15
Product Dimension with Stand (WxDxH) (mm)613.5 x 200.8 x 413.3
Product Dimension with Stand (WxDxH) (inch)24.15 x 7.91 x 16.27
Weight Without Stand (kg)3.9
Warranty36M
3.5mm Mic Cable0
Switch Case0
Portable Screen Protection Case0
Monitor Hood0
Speaker (Accessories)0
DisplayPort Cable0
HDMI Cable1
DVI Cable0
USB Type A to Type B Cable1
USB Type C to Type A Cable0
USB Type C to Type C Cable0
Thunderbolt Cable0
VGA Cable0
3.5mm audio Cable0
3.5mm combo audio Cable0
Mouse Bungee Unit0
VESA Screw4
Power Cord1
AC Adaptor1
Warranty Card0
Quick Guide1
EAN4711377078726
Screen Size27" (69 cm)
Active Display Area (mm)596.736(H)×335.664(V)
CurvatureFlat
Panel TypeIPS
Resolution2560x1440 (WQHD)
Pixel pitch (mm)0.2331(H)x0.2331(V)
HDR (High dynamic range)DsiplayHDR 400
HDR Brightness (Peak nits)400
Refresh Rate100HZ
Response Time (MPRT)1ms(MPRT)
Response Time (GTG)4
View Angles178°(H)/178°(V)
sRGB (CIE1976 area percentage/overlap)115%/99%
sRGB (CIE1931 area percentage/overlap)121%/99%
Adobe RGB (CIE1976 area percentage/overlap)100%/93%
Adobe RGB (CIE1931 area percentage/overlap)90%/85%
DCI-P3 (CIE1976 area percentage/overlap)93%/92%
DCI-P3 (CIE1931 area percentage/overlap)89%/87%
Rec.709 (CIE1976 area percentage/overlap)115%/99%
Rec.709 (CIE1931 area percentage/overlap)121%/99%
Rec.2020 (CIE1976 area percentage/overlap)66%/66%
Rec.2020 (CIE1931 area percentage/overlap)64%/64%
Display Colors1.07B
Color bit10 bits (8 bits + FRC)
UPC824142317525
Part No9S6-3PB19H-082
UCC1410824142317522
MKT NameModernModern MD272QXP
MKT SpecModernModern MD272QXP
ColorID1/Black-Black
Model3PB1
Tags:MSI, Pantallas
