Antec Skeleton 360 ARGB Review: estética y rendimiento se dan de la mano
Mostrando página 2 de 4
Especificaciones del Antec Skeleton 360 ARGB
Foto de la refrigeración líquida
Fan
Dimensions120 x 120 x 25 mm
TypePWM ARGB LED Fan
Speed800 ± 200 ~ 2000 ± 10% RPM
Airflow72.29 CFM (max.)
Noise≤32 dB(A)
Air pressure3.28 mmH₂O (max.)
Lifespan50,000 hours at 40℃ room, ambient 15-65% RH
ConnectorFan: 4pin, ARGB: 3pin
Radiator
Dimensions397 x 120 x 27 mm
MaterialAluminum, Polycarbonate
Head
Dimensions¢67.5 x 66 mm
ConnectorPUMP: 4-pin | LED: 3-pin
Water Pressure1.4m
Flow rate≥1300 mL/min
Lifespan40,000 hours
Noise≤30 dB(A)
Miscellaneous
Socket CompatibilityIntel:LGA115X / 1200 / 1700 / 1851 / 20XX
AMD:AM3 / AM4 / AM5
Warranty3 Years
UPC#0-761345-40066-4
Net Weight1.42 kg
Gross Weight2.01 Kg
Tags:Antec, Refrigeración
