Corsair MP700 Micro Review: un NVMe compacto muy exclusivo
Mostrando página 2 de 6
Especificaciones del Corsair MP700 Micro
Foto del disco externo
CAPACITY2000GB4000GB
Part NumberCSSD-F2000GBMP700MCRCSSD-F4000GBMP700MCR
Form FactorM.2 2242M.2 2242
InterfaceNVMe PCIe 5.0 x4NVMe PCIe 5.0 x4
ControllerPhison PS5031-E31TPhison PS5031-E31T
NAND3D TLC3D TLC
DRAM Cache Size- (HMB)- (HMB)
NAND Cache SizeDynamic SLCDynamic SLC
Encryption--
Trim SupportSupportedSupported
S.M.A.R.T SupportSupportedSupported
Garbage CollectionSupportedSupported
TBW Rating12002400
MTBF1,600,000hrs1,600,000hrs
Dev Slp power< 3.5mW< 3.5mW
Average Active Read5.9W5.9W
Average Active Write5.9W5.9W
Operating Temperature0° C~70° C0° C~70° C
Storage Temperature-40° C~85° C-40° C~85° C
Operating Humidity90% RH (40° C)90% RH (40° C)
Storage Humidity93% RH (40° C)93% RH (40° C)
Shock1500G1500 G
Vibration20Hz~80Hz/1.52mm, 80Hz~2000Hz/20G20Hz~80Hz/1.52mm, 80Hz~2000Hz/20G
Dimensions22mm x 42mm x 2.4mm22mm x 42mm x 2.4mm
Sequential Read (CDM) (2) (4)Up to 10,000MB/sUp to 9,400MB/s
Sequential Write (CDM) (2) (4)Up to 8,500MB/sUp to 8,100MB/s
4KB Random Read (3) (4)Up to 1.3MUp to 1.2M
4KB Random Write (3) (4)Up to 1.4MUp to 1.4M
* Sequential performance measurements based on CrystalDiskMark v8.0.4. Random performance measurements based on Iometer, 1GB range, 4K data size, QD=32, 16 worker, 4K aligned. Performance may vary based on SSD’s firmware version, system hardware & configuration.
* Dynamic SLC caching schema is defined as data being programmed into SLC cache while data is moved into TLC blocks during available cycles and/or garbage collection of the SSD.
*1 GB=1 Billion bytes. Actual usable capacity may be less (due to formatting, partitioning, operating system, applications or otherwise).
Tags:Corsair, Almacenamiento, SSD
