darkFlash DY570 ATX PC Case Review: panorámica, completa y espaciosa
Mostrando página 3 de 4
Especificaciones
Foto del frontal y la tapa izquierda
Key Specs
Motherboard SupportATX, M-ATX, ITX
Drive Bays
SSD1
HDD2
Front I/O
I/OPower, Reset, LED, HD Audio, USB-A, USB-C
USB-A3.0
USB-C3.2 Gen2
Dimensions
Case Size479*303*466mm
Fan Support
Top120mm*3, 140mm*2
Side120mm*3
Rear120mm*1,140mm*1
Bottom120mm*3
Compatibility & Clearance
Max GPU Clearance400mm
PCIE Slot7
Max CPU Cooler Clearance180mm
Radiator Support
Top240mm, 360mm
Side240mm, 360mm
Rear120mm
Tags:darkFlash, Cajas de ordenador
