ASUS ROG Strix ACE XG248QSG Review: el máximo refresco en un monitor gaming competitivo
Mostrando página 2 de 4
Especificaciones del ASUS ROG Strix ACE XG248QSG
Foto lateral del monitor
Display
Panel Size (inch) : 24.1
Aspect Ratio : 16:9
Color Space (DCI-P3) : 90%
Color Space (sRGB) : 125%
Panel Type : Super TN
True Resolution : 1920x1080
Display Viewing Area (HxV) : 535.68 x 298.08 mm
Display Surface : Anti-Glare
Pixel Pitch : 0.279mm
Brightness (Typ.) : 350cd/㎡
Brightness (HDR, Peak) : 400 cd/㎡
Contrast Ratio (Typ.) : 1000:1
Viewing Angle (CR≧10) : 170°/ 160°
Response Time : 0.7ms(GTG), 0.1ms(min.)
Color Accuracy: △E< 2
Display Colors : 16.7M
Flicker free : Yes
HDR (High Dynamic Range) Support : HDR10
Refresh Rate (max) : 610Hz
Features
GamePlus: Yes
Game Visual: Yes
VRR Technology: FreeSync™ Premium & G-SYNC® Compatible
Extreme Low Motion Blur: Yes, ELMB 2
Shadow Boost: Yes
Aspect Control: Yes
I/O Ports
DisplayPort 1.4 DSC x 1
HDMI (v2.1) x 2
Earphone jack : Yes
AudioSpeaker: No
Signal Frequency
Digital Signal Frequency : HDMI: 27~851 KHz (H) / 24~610 Hz (V)
DisplayPort: 27~851 KHz (H) / 24~610 Hz (V)
Power Consumption
Power Consumption : <24W
Power Saving Mode : <0.5W
Power Off Mode : <0.3W
Voltage : 100-240V, 50/60Hz
Mechanical Design
1/4" Tripod Socket : Yes
Tilt : Yes (+35° ~ -5°)
Swivel : Yes (+45° ~ -45°)
Height Adjustment : 0~160mm
VESA Wall Mounting : 100x100mm
Lighting effect (Aura) : Aura Sync
Kensington Lock : Yes
Dimensions
Phys. Dimension with stand (W x H x D) : 55.7 x 51.4 x 18.8 cm (21.93" x 20.24" x 7.40")
Phys. Dimension without Stand (W x H x D) : 55.7 x 33.3 x 8.5 cm (21.93" x 13.11" x 3.35")
Box Dimension (W x H x D) : 74.2 x 22.8 x 41.4 cm (29.21" x 8.98" x 16.30")
Weight
Net Weight with Stand : 5.6 kg (12.35 lbs)
Net Weight without Stand : 3.3 kg (7.28 lbs)
Gross Weight : 8.2 kg (18.08 lbs)
Accesories
DisplayPort cable
Power adapter
Power cord
Quick start guide
ROG pouch
ROG sticker
Warranty Card
Certificate
TÜV Flicker-free
TÜV Low Blue Light
VESA DisplayHDR 400
AMD FreeSync Premium
G-SYNC Compatible
Tags:ASUS, Pantallas, Gaming
