MSI MPG CORELIQUID P13 360 WHITE Review: rendimiento y elegancia con pantalla LCD
Mostrando página 2 de 4
Especificaciones del MSI MPG CORELIQUID P13 WHITE
Foto del radiador con los ventiladores
Radiator Size360 mm
Radiator Dimensions (WxDxH)394 x 119.6 x 27.2mm / 15.51 x 4.69 x 1.06 inches
Radiator MaterialAluminum
Water Cooling Tube MaterialEPDM
Number of Fans3
Fan Dimensions (WxDxH)120 x 120 x 25 mm / 4.7 x 4.7 x 0.98 inches
Fan Air Flow64.89 CFM
Fan BearingRifle
Fan Speed500~2050 ± 150 RPM
Fan Life Expectancy40,000 hrs@40℃
Fan Rated Current0.14 A±0.028 A
Fan Power Consumption1.68W±0.336W
PWM ModeYes
Cable Length (PWM Cable)800 mm; 31.49 inches
Fan Connector5V ARGB 3-PIN Header
Fan LightingARGB GEN2
Pump Life Expectancy50,000 hours in typical use
Pump Noise Level20 dBA ( Max )
Pump Rated Current0.21A±0.042
Pump Power Consumption2.52W±0.504W
Pump Speed3400 RPM ± 10% RPM
Intel Socket SupportLGA 1700 / 1851
AMD Socket SupportAM5 / AM4
Panel Size2.1"
Panel TypeIPS
Panel Resolution480 x 480
Panel Bridghtness600 nits
Tags:MSI, Refrigeración
  • Antec Flux Pro Noctua Edition Review: caja premium con 6 ventiladores Noctua y rendimiento térmico top
