Corsair iCUE LINK Titan 420 RX RGB Review: AIO tope de gama con la mejor gestión de software y cableado
Mostrando página 2 de 4
Especificaciones del Corsair iCUE LINK Titan 420 RX RGB
Foto del radiador con los ventiladores
Product Length452
Product Width137
Product Height145
LightingRGB
Cooling Warranty6 Year
AMD Processors SupportedRyzen
Intel Processors SupportedCore i9, i7, i5, i3, Pentium, Celeron
Fan Control MethodDigital
Tubing MaterialBlack Sleeved Low-Permeation Rubber
Tubing Length450mm
Radiator Size420mm
Cooling Socket SupportIntel 1851, Intel 1700, AMD AM5, AMD AM4
PWMNo
Fan Speed300 - 1700 RPM ±10%
Fan Dimensions140mm x 25mm
Cold Plate MaterialCopper
Number of Fans3
Radiator MaterialAluminum
Radiator Dimensions457mm x 140mm x 27mm
Weight2.923
Fan Airflow17.9 - 94.7 CFM
Fan Static Pressure0.15 - 3.75mm-H2O
Tags:Corsair, Refrigeración
