Especificaciones de la AORUS Radeon RX 9070 XT ELITE 16G
Graphics Processing | GeForce RTX™ 5080 |
Core Clock | 2730 MHz (Reference: 2617 MHz) |
CUDA® Cores | 10752 |
Memory Clock | 30 Gbps |
Memory Size | 16GB |
Memory Type | GDDR7 |
Memory Bus | 256 bit |
Card Bus | PCI-E 5.0 |
Digital max resolution | 7680x4320 |
Multi-view | 4 |
Card size | L=340 W=140 H=70 mm |
PCB Form | ATX |
DirectX | DirectX 12 API |
OpenGL | OpenGL 4.6 |
Recommended PSU | 850W |
Power Connectors | 16 pin*1 |
Output | DisplayPort 2.1b x3 HDMI 2.1b x1 |
Accessories | 1. VGA manual 2. Warranty notice 3. 1x 12V-2x6 to 3x PCIe 8pin adapter 4. Versatile VGA holder 5. Versatile VGA holder manual |
