MSI MAG CORELIQUID A15 360 Review: Buen rendimiento y gran estética con ARGB
Mostrando página 2 de 4
Especificaciones del MSI MAG CORELIQUID A15 360
Foto del radiador con los ventiladores
Radiator Size360 mm
Radiator Dimensions (WxDxH) 394 x 119.6 x 27.2mm / 15.51 x 4.69 x 1.06 inches
Radiator MaterialAluminum
Water Cooling Tube MaterialEPDM + IIR
Number of Fans3
Fan Dimensions (WxDxH)120 x 120 x 25 mm / 4.7 x 4.7 x 0.98 inches
Fan Air Flo64.89 CFM
Fan BearingRifle
Fan Speed500~2050 ± 150 RPM
Fan Life Expectancy40,000 hrs@40℃
Fan Rated Current0.14 A±0.028 A
Fan Power Consumption1.68W±0.336W
PWM Mode Yes
Cable Length (PWM Cable)600 mm; 23.62 inches
Fan Connector5V ARGB 3-PIN Header
Block LightingARGB GEN2
Fan LightingARGB GEN2
Pump Life Expectancy50,000 hours in typical use
Pump Noise Level20 dBA ( Max )
Pump Rated Current0.21A±0.042
Pump Power Consumption2.52W±0.504W
Pump Speed3400 RPM ± 10% RPM
Pump Connector4-PIN Header
5V ARGB 3-PIN Header ( Female )
Cold Plate Material Copper
 Block Dimensions (WxDxH) 71.23 x 69.47 x 75.05 mm
Intel Socket Support LGA 1851 / 1700
AMD Socket SupportAM5 / AM4
AccessoriesThermal paste x 1
Screws x 12
Tags:MSI, Refrigeración
