NVIDIA GeForce RTX 5090 Review: innovación en tecnologías y refrigeración para una reina de tamaño compacto
Mostrando página 4 de 25
Especificaciones de la NVIDIA GeForce RTX 5090
Foto de la GPU dentro de su caja
GPU Engine Specs:NVIDIA CUDA® Cores21760
 Shader CoresBlackwell
 Tensor Cores (AI)5th Generation
3352 AI TOPS
 Ray Tracing Cores4th Generation
318 TFLOPS
 Boost Clock (GHz)2.41
 Base Clock (GHz)2.01
Memory Specs:Standard Memory Config32 GB GDDR7
 Memory Interface Width512-bit
Technology Support:NVIDIA ArchitectureBlackwell
 Ray TracingYes
 NVIDIA DLSSDLSS 4
Super Resolution
DLAA
Ray Reconstruction
Frame Generation
Multi Frame Generation
 NVIDIA ReflexReflex 2
Low Latency Mode
Frame Warp (Coming Soon)
 NVIDIA BroadcastYes
 PCI Express Gen 5Yes
 Resizable BARYes
 NVIDIA AppYes
 NVIDIA AnselYes
 NVIDIA FreeStyleYes
 NVIDIA ShadowPlayYes
 NVIDIA HighlightsYes
 NVIDIA G-SYNC®Yes
 Game Ready DriversYes
 NVIDIA Studio DriversYes
 NVIDIA OmniverseYes
 RTX RemixYes
 Microsoft DirectX® 12 UltimateYes
 NVIDIA GPU Boost™Yes
 NVIDIA NVLink™ (SLI-Ready)No
 Vulkan 1.4, OpenGL 4.6Yes
 NVIDIA Encoder (NVENC)3x Ninth Generation
 NVIDIA Decoder (NVDEC)2x Sixth Generation
 AV1 EncodeYes
 AV1 DecodeYes
 CUDA Capability12.8
 VR ReadyYes
Display Support:Maximum Digital Resolution (1)4K at 480Hz or 8K at 120Hz with DSC
 Standard Display Connectors3x DisplayPort(2), 1x HDMI(3)
 Multi Monitorup to 4(4)
 HDCP2.3
Card Dimensions:Length304 mm
 Width137 mm
 Slot2-Slot
 SFF-Ready Enthusiast GeForce CardFounders Edition Yes
Varies by manufacturer
Thermal and Power Specs:Maximum GPU Temperature (in C)90
 Total Graphics Power (W)575
 Required System Power (W) (5)1000
 Supplementary Power Connectors4x PCIe 8-pin cables (adapter in box) OR
1x 600 W PCIe Gen 5 cable
1 - Up to 4K 12-bit HDR at 480Hz with DP 2.1b + DSC. Up to 8K 12-bit HDR at 165Hz with DP 2.1b + DSC or HDMI 2.1a + DSC. With dual DP 2.1b + DSC, up to 8K HDR at 100Hz
2 - DisplayPort 2.1b with UHBR20: up to 4K 480Hz or 8K 165Hz with DSC
3 - As specified in HDMI 2.1b: up to 4K 480Hz or 8K 120Hz with DSC, Gaming VRR, HDR
4 - Multi Monitor
  1. 4 independent displays at 4K 165Hz using DP or HDMI
  2. 2 independent displays at 4K 360Hz or 8K 100Hz with DSC using DP or HDMI
  3. Other display configurations may be possible based on available bandwidth
5 - Minimum is based on a PC configured with a Ryzen 9 9950X processor. Recommend PCIe CEM 5.1 compliant PSU. Power requirements can be different depending on system configuration.
Note: The above specifications represent this GPU as incorporated into NVIDIA's Founders Edition or reference graphics card design. Clock specifications apply while gaming with medium to full GPU utilization. Graphics card specifications may vary by add-in-card manufacturer. Please refer to the add-in-card manufacturers' website for actual shipping specifications.
Tags:NVIDIA, RTX 5090, NVIDIA Blackwell, Tarjetas Gráficas
Ver comentarios (3)
