Antec Performance 1M Review: caja Mini-ITX gaming con calidad máxima
Mostrando página 3 de 4
Especificaciones
Vista diagonal de la torre
Main Spec
Motherboard SupportITX
Form FactorMini ITX
Case materialSteel + Plastic + Aluminum
Side Window MaterialSolid Side Panel
I/O PortsPower, Type-C 10Gbps x 1
Case Dimensions (DxWxH)424 x 175 x 260 mm
Box Dimensions (DxWxH)506 x 259 x 332 mm
Compatability & Clearances
GPU Max Length≤ 350mm
CPU Cooler Max Height≤ 85mm (40m Max GPU Thickness)
Max GPU Thickness≤ 78mm (47mm Max CPU Cooler Height)
Total GPU Thickness + CPU Cooler Height125mm
Max PSU Size130 x 125 x 63.5mm / SFX-L & SFX only
Fan Support
Bottom120mm x 2 / 140mm x 2
Expansion Slots
Standard3 (Max GPU Mode) / 2 (Max CPU-Cooler Mode)
Drive Bays
2,5"1
General
Dust FilterBottom
Net Wieght4.90 kg
Gross Weight5.75 kg
Warranty2 years
UPC#0-761345-10168-4
Tags:Antec, Cajas de ordenador, Gaming
Ver comentarios (1)
