Especifcaciones del MSI MAG CORELIQUID I360
Number of Fans | 3 |
Fan Dimensions | 120 x 120 x 25 mm / 4.7 x 4.7 x 0.98 inches |
Fan Power Consumption | 2.4W (MAX:3.6W) |
Fan Rated Current | 0.2A (MAX:0.3A) |
Fan Life Expectancy | 30,000 hrs@40℃ |
Fan Bearing | Loop Dynamic Bearing(LDB) |
Radiator Size | 360 mm |
Fan Air Flow | 70.7 CFM |
Fan Lighting | ARGB Gen2 |
Water Cooling Tube Material | EPDM |
PWM Mode | Yes |
Fan Cable Length (5V ARGB / PWM cable) | 550 / 500 mm; 21.65 / 19.69 inches |
Radiator Material | Aluminum |
Radiator Dimensions | 394 x 120 x 27 mm / 15.5 x 4.7 x 1.06 inches |
Block Dimensions | 69.1 x 74 x 62.45 mm |
Block Lighting | ARGB Gen2 |
Fan Connector | 5V ARGB 3-PIN Header |
Pump Life Expectancy | 50,000 hours in typical use |
Pump Noise Level | 20 dBA (avg.) |
Pump Speed | 3400 RPM ± 10% |
Pump Rated Current | 0.32A (Max: 0.5A) |
Pump Power Consumption | 3.84W (Max: 6W) |
Pump Connector | PWM 4-PIN Header 5V ARGB 3-PIN Header ( Female ) 5V ARGB 3-PIN Header ( male ) |
Intel Socket Support | LGA 1150/1151/1155/1156/1200/1700 + Next gen |
AMD Socket | AM5 / AM4 |
Accessories | Thermal paste x 1 |
Cold Plate Material | Cooper |
