MSI MAG 274URFW Review: Un panel IPS rápido y con gran detalle
Mostrando página 2 de 4
Especificaciones del MSI MAG 274URFW
Vista frontal del MSI MAG 274URFW
Panel Size27" (69 cm)
Active Display Area (mm)596.16(H) x 335.34(V)
CurvatureFlat
Panel TypeRapid IPS
Panel Resolution3840x2160 (UHD)
Pixel Pitch (H x V)0.15525(H) x 0.15525(V)
Aspect Ratio16:9
Brightness (nits)400 Nits (Typ.)
Contrast Ratio1000:1 (Typ.)
DCR100000000:1
Signal Frequency180~352KHz(H) / 48~160Hz(V)
Activated Range48 to 160Hz
Refresh Rate160 Hz
Response time0.5ms (GtG, Min.)
Dynamic Refresh Rate TechnologyAMD FreeSync™ Premium
HDR SupportVESA DisplayHDR 400
Video ports1 x DisplayPort 1.4a
2 x HDMI™ 2.1 (4K@160Hz)
1 x Type-C (DP Alt.) w/ PD 15W
USB ports N/A
Audio ports 1 x Headphone-out
Viewing Angle178°(H) / 178°(V)
Adobe RGB / DCI-P3 / sRGB93% / 98% / 133%
Surface TreatmentAnti-glare
Display Colors1.07B , 10 bits (8 bits + FRC)
Power Type External Adopter19V 3.42A
Power Input100-240V~ 50/60Hz
Adjustment (Tilt)-5° ~ 20°
Adjustment (Swivel)-30° ~ 30°
Adjustment (Pivot)-90° ~ 90°
Adjustment (Height)0 ~ 130 mm
Kensington LockYes
Dimension (W x D x H)613.5 x 227.8 x 406.6 mm
613.5 x 69.8 x 362.5 mm (without stand)
Carton Dimension (W X D X H)WW carton: 847 x 145 x 491 mm
Frameless DesignYes
PIP / PBP FunctionYes
VESA Mounting75 x 75 mm
Weight (NW / GW)6.4 / 8.8kg
NoteDisplayPort: 3840 x 2160 (Up to 160Hz)
Type C (DP alt.): 3840 x 2160 (Up to 160Hz)
HDMI™: 3840 x 2160 (Up to 160Hz)
Adobe RGB, DCI-P3 and sRGB follow CIE1976 Standard
Connections5-Way Joystick Navigator
DC-in
Headphone Out
1 x DisplayPort (1.4a)
USB Type-C (PD15W)
Kensington Lock
Tags:MSI, Pantallas, Gaming
