MSI MAG 274QRFW Review: Elegancia y rendimiento a un precio comedido
Mostrando página 2 de 4
Especificaciones del MSI MAG 274QRFW
Vista digonal del MSI MAG 274QRFW
Panel Size27" (69 cm)
Active Display Area (mm)596.736(H) x 335.664(V)
CurvatureFlat
Panel TypeRapid IPS
Panel Resolution2560 x 1440 (WQHD)
Pixel Pitch (H x V)0.2331(H) x 0.2331(V)
Aspect Ratio16:9
Brightness (nits)400 (Typ.)
Contrast Ratio1000:1 (Typ.)
DCR100000000:1
Signal Frequency64.56~266.4 KHz(H) / 48~180 Hz(V)
ACTIVATED RANGE48~180Hz
Refresh Rate180 Hz
Response time1ms (GTG)
DYNAMIC REFRESH RATE TECHNOLOGYAdaptative-Sync
HDR SupportVESA DisplayHDR 400
Video ports1 x DisplayPort (1.4a)
2 x HDMI™ (2.0b)
USB portsN/A
Audio ports1 x Headphone Out
Viewing Angle178° (H) / 178° (V)
Adobe RGB / DCI-P3 / sRGB93% / 95% / 123%
Surface TreatmentAnti-Glare
Display Colors1.07B , 10 bits (8 bits + FRC)
Power TypeExternal Adaptor 19V 2.58A
Power Input100 ~ 240V, 50/60Hz
Adjustment (Tilt)-5° ~ 20°
Adjustment (Swivel)-45° ~ 45°
Adjustment (Pivot)-90° ~ 90°
Adjustment (Height)0 ~ 130mm
Kensington LockYes
Dimension (W x D x H)TBD
Frameless DesignYes
PIP / PBP FunctionYes
VESA Mounting75 x 75 mm
Weight (NW / GW)TBD
NoteDisplay Port: 2560x1440 (Up to 180Hz)
HDMI™: 2560x1440 (Up to 144Hz)
*Adobe RGB, DCI-P3 and sRGB follow CIE1976 Standard
Tags:MSI, Pantallas, Gaming
  • Insta360 X5 Esencial Kit 8K
