MSI PRO AP162T ADL Review: funcionalidad en un robusto TPV
Mostrando página 3 de 7
Especificaciones del MSI PRO AP162T ADL
MSI PRO AP162T ADL, vista diagonal
CPU
Intel® N200
Intel® N100
OSWindows 11 Home - MSI recommends Windows 11 Pro for business
CHIPSETIntel® SoC
STORAGE1x M.2 SSD (PCIE)
1x 2.5” HDD with HDD Caddy
GRAPHICSIntel® UHD Graphics
MEMORY1x DDR4 3200MHz SO-DIMMs, up to 16GB
PANEL RESOLUTION15.6" IPS Grade Panel LED Backlight (1920 x 1080 FHD)
TOUCH PANELResistive Single Touch (PRO AP162T ADL)
Non-touch (PRO AP162 ADL)
AUDIO SPEAKER2x 2.5W
I/OSide:
1x Card reader
2 x USB 3.2 Gen 2 Type A
Rear:
1 x Line-out/Microphone-in
4 x USB 2.0 Type A
2 x RJ-45 LAN
1 x VGA Port
2 x Serial Port (COM Port)
1 x Parallel Port (Printer Port)
AUDIORealtek® ALC256
LAN2x Realtek RTL8111H
WIRELESS LANIntel® Wi-Fi 6E AX211
Intel® Wi-Fi AC 9462 (either one)
BLUETOOTH5.3 (AX211) / 5.1 (AC 9462)
WEBCAMBuilt-in HD Webcam
KEYBOARD / MOUSEOptional
AC ADAPTER65W
AIO WALL MOUNT KIT IIIVESA standard (STD 100*100mm) (Optional)
MANAGEMENT UTILITYMSI Center: Hardware Monitoring, Free Up Memory, Clean Up Disk, MSI Recovery, F3 Recovery, Devices Speed Up, Smart Priority, Smart Image Finder, Live Update, Microsoft App Update, System Info, Troubleshooting, Contact Us, MSI Forum & Channel
MSI Display Kit: Split Window, Display Setting (Orientation, resolution, refresh rate, size of text and app), Display Color Setting (Customizable Link App: Eye Saver Mode, Personal setting, Standard, Gaming, FPS, RTS/RPG, Cinema), Connect to wireless display, On-screen keyboard, Mouse Sensitivity, Power setting, Magnifier (Zoom in / Zoom out), Project way setting (internal/ Clone/ Extend/ External)
SECURITY UTILITY & DEVICEMSI Center: System Diagnosis
NET WEIGHT3.94 kg (8.69 lbs)
GROOS WEIGHT5.78 kg (12.74 lbs)
CERTIFICATESFCC, CB/CE, UL & CUL, VCCI, RCM
Tags:MSI, MiniPC
