G.Skill Trident Z5 RGB DDR5 F5-7200J3646F24GX2-TZ5RW Review: alta capacidad y rendimiento extremo
Mostrando página 2 de 7
Especificaciones del kit de memoria G.Skill Trident Z5 RGB DDR5 F5-7200J3646F24GX2-TZ5RW
Foto de los módulos de RAM en horizontal
Especificaciones
Memory TypeDDR5
Capacity32GB (16GBx2)
Memory TypeDDR5
Multi-Channel KitDual Channel Kit
Tested Speed (XMP/EXPO)7200 MT/s
Tested Latency (XMP/EXPO)36-46-46-115
Tested Voltage (XMP/EXPO)1.35V
Registered/UnbufferedUnbuffered
Error CheckingNon-ECC
SPD Speed4800MT/s
SPD Voltage (Default)1.10V
Fan IncludedNo
WarrantyLimited Lifetime
FeaturesIntel XMP 3.0 (Extreme Memory Profile) Ready
Additional Notes
  • Do not mix memory kits. Memory kits are sold in matched kits that are designed to run together as a set. Mixing memory kits will result in stability issues or system failure.
  • Memory kits will boot at the SPD speed at default BIOS settings with compatible hardware.
  • For memory kits with XMP/EXPO, enable XMP/EXPO/DOCP/A-XMP profile in BIOS to reach the rated potential XMP/EXPO overclock speed of the memory kit, subject to the use of compatible hardware. Please refer to the "How to Enable XMP/EXPO" guide.
  • Reaching the rated XMP/EXPO overclock speed and system stability will depend on the compatibility and capability of the motherboard and CPU used.
  • Usage in any manner inconsistent with manufacturer specifications, warnings, designs, or recommendations will result in lower speeds, system instability, or damage to the system or its components.
  • Memory module height can be found in the FAQ, under the question "How tall are the memory modules?".
  • For product support and related questions, please contact the G.SKILL technical support team via email.
Tags:G.SKILL, Memoria
