Nfortec Atria X 240 Review: buen kit refrigeración líquida A-RGB
Mostrando página 2 de 4
Especificaciones
Foto de la refrigeración líquida, vista del radiador
PARAMETERS
MODELATRIA X 240mm
SUPPORTSIntel LGA1700/LGA1800/LGA1200/LGA1150/LGA1151/LGA1155/LGA1156
LGA2066/LGA2011/LGA2011-V3/LGA1366
AMD AM5/AM4/AM3+/AM3/AM2+/TR4/TRX4/FM2+/FM2/FM1
A-RGB5v 3pin A-RGB
WIGHT1.347Kg
TDP max240W
FANS
DIMENSIONS120mm x 120mm x x25mm (x2)
SPEED500 RPM - 1800±10% RPM
AIRFLOW59.18±10% CFM
STATIC PRESSURE1.42mmH2O ±10%
NOISE LEVEL29.96dBA ±10%
PWM CONTROLYes
PUMP
DIMENSIONS71.5x52.3mm
PLATE MATERIAL / TYPE OF PUMPCopper / Centrifugal Pump
PUMP MOTORThree-Phase DC Brushless Motor
PUMP BEARINGStainless Steel And Cooper Alloy
PUMP SPEED3200±10% RPM
WATER PRESSURE / FLOW RATE1500 mmH2O / 156L/h
RADIATOR
DIMENSIONS272x121x27mm
MATERIALAluminium
TUBING LENGHT395±5mm
Tags:Nfortec, Refrigeración
  • Insta360 X5 Esencial Kit 8K
