Especificaciones del kit de memoria G.SKILL TRIDENT Z5 RGB DDR5 F5-7200J3445G16GX2-TZ5RK
Especificaciones
| Memory Type | DDR5 |
| Capacity | 32GB (16GBx2) |
| Multi-Channel Kit | Dual Channel Kit |
| Tested Speed (XMP/EXPO) | 7200 MT/s |
| Tested Latency (XMP/EXPO) | 34-45-45-115 |
| Tested Voltage (XMP/EXPO) | 1.40V |
| Registered/Unbuffered | Unbuffered |
| Error Checking | Non-ECC |
| SPD Speed | 4800MT/s |
| SPD Voltage (Default) | 1.10V |
| Fan Included | No |
| Warranty | Limited Lifetime |
| Features | Intel XMP 3.0 (Extreme Memory Profile) Ready |
| Additional Notes | - Do not mix memory kits. Memory kits are sold in matched kits that are designed to run together as a set. Mixing memory kits will result in stability issues or system failure.
- Memory kits will boot at the SPD speed at default BIOS settings with compatible hardware.
- For memory kits with XMP/EXPO, enable XMP/EXPO/DOCP/A-XMP profile in BIOS to reach the rated potential XMP/EXPO overclock speed of the memory kit, subject to the use of compatible hardware. Please refer to the "How to Enable XMP/EXPO" guide.
- Reaching the rated XMP/EXPO overclock speed and system stability will depend on the compatibility and capability of the motherboard and CPU used.
- Usage in any manner inconsistent with manufacturer specifications, warnings, designs, or recommendations will result in lower speeds, system instability, or damage to the system or its components.
- Memory module height can be found in the FAQ, under the question "How tall are the memory modules?".
- For product support and related questions, please contact the G.SKILL technical support team via email.
