Sapphire Nitro+ Radeon RX 6750 XT Gaming OC 12 GB
Mostrando página 2 de 21
Especificaciones de la Sapphire Nitro+ Radeon RX 6750 XT
Foto del emboltorio
Especificaciones
GPU
AMD Radeon™ RX 6750 XT Graphics Card
7nm GPU
AMD RDNA™ 2 Architecture
Engine Clock
  • Boost Clock: Up to 2623 MHz
  • Game Clock: Up to 2554 MHz
Boost Clock is the maximum frequency achievable on the GPU running bursty workload. Boost clock achievability, frequency, and sustainabilty will vary based on several factors, including but not limited to: thermal conditions and variation in application and workloads.
Game Clock is the expected GPU clock when running typical gaming applications, set to typical TGP(Total Graphics Power). Actual individual game clock results may vary.
Stream Processors
2560
Infinity Cache
96MB
Ray Accelerators
40
Memory Size/Bus
12GB GDDR6
Memory Clock
18 Gbps Effective
Displays
Maximum 4 Displays
Resolution
  • HDMI™: 7680×4320
  • DisplayPort1.4: 7680×4320
Interface
PCI-Express 4.0 x16
Output
  • 1x HDMI
  • 3x DisplayPort
BIOS Support
  • Dual UEFI
Game Index
1440P
Sapphire Features
  • Dual BIOS
  • TriXX Software BIOS Switch
  • Premium Digital Power Design
  • Fuse Protection
  • High TG Copper PCB
  • Optimized Composite Heatpipe
  • Tri-X Cooling Technology
  • Intelligent Fan Control
  • Precision Fan Control
  • Backplate with ARGB
  • Metal Backplate with Thermal Pad
  • Two-Ball Bearing Fans
  • Angular Velocity Fan Blade
  • Wave Fin Design
  • V Shape Fin Design for GPU Cooling
  • Integrated Cooling Module
  • TriXX Supported
  • Fan Check
  • Fan Quick Connect
  • Graphics Card Supporter
  • TriXX Boost
  • NITRO Glow
  • External RGB LED MB Synchronization
AMD Features
  • AMD RDNA™ 2 Gaming Architecture
  • DirectX® 12 Ultimate
  • Hardware Raytracing
  • GDDR6 Memory
  • Smart Access Memory
  • Infinity Cache
  • 7nm GPU
  • PCI® Express 4.0 Support
  • AMD FreeSync™ Technology
  • DisplayPort™ 1.4 with DSC
  • HDMI™
  • Video Streaming up to 8K
  • Radeon™ VR Ready Premium
  • AMD FidelityFX
  • AMD FidelityFX™ Super Resolution (FSR)
  • AMD Radeon™ Super Resolution
  • Radeon™ Image Sharpening
  • Radeon™ Anti-Lag
  • Radeon™ Software
  • Game Driver Optimizations
Cooling
3 Fans
Form Factor
3 slot, ATX
Dimension: 310(L)X 130.75(W)X 62.19 (H)mm
Power Consumption
273W Total Board Power
OS
Linux®, Windows® 7*, Windows® 10, and Windows 8.1. 64-bit  operating system required
*Does not support all features including but not limited to Hardware Raytracing
System Requirement
  • Minimum 650 Watt Power Supply
  • 1 x 8-pin + 1 x 6-pin Power Connector.
  • PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard.
  • Minimum 8GB of system memory. 16GB recommended.
Tags:Sapphire, Radeon RX 6750 XT, Tarjetas Gráficas
