Especificaciones del kit de memoria DDR5 GSKILL Trident Z5 RGB F5-6000J3636F16GX2-TZ5RS
Especificaciones
| Memory Type | DDR5 |
| Capacity | 32GB (16GBx2) |
| Multi-Channel Kit | Dual Channel Kit |
| Tested Speed (XMP) | 6000 MT/s |
| Tested Latency | 36-36-36-96 |
| Tested Voltage | 1.35V |
| Registered/Unbuffered | Unbuffered |
| Error Checking | Non-ECC |
| SPD Speed (Default) | 4800 MT/s |
| SPD Speed | 4800MHz |
| SPD Voltage | 1.10V |
| Fan Included | No |
| Warranty | Limited Lifetime |
| Features | Intel XMP 3.0 (Extreme Memory Profile) Ready |
| Additional Notes | The memory kit will boot at the SPD speed when BIOS settings are at default. Enable XMP/DOCP/A-XMP profile in the BIOS to reach up to the rated XMP overclock speed of the memory kit. Reaching the rated XMP overclock speed and system stability depends on the capability of the motherboard & CPU. |
