AORUS FO48U Gaming Monitor
Mostrando página 2 de 4
Especificaciones del AORUS FO48U Gaming Monitor
  • Panel Size (diagonal)
    47.53" OLED
  • Display Viewing Area (HxV)
    1052.16 x 591.84 (mm)
  • Panel Backlight/ Type
    OLED
  • Display Surface(non-glare/ glare)
    Anti-Reflection
  • Color Saturation
    98% DCI-P3 / 130% sRGB
  • True Resolution
    3840 x 2160 (UHD)
  • Pixel Pitch
    0.274(H) x 0.274(V) (mm)
  • Brightness
    130-150 cd/m2 (typical)
    800-900 cd/m2 (@3% peak)
  • Contrast Ratio
    135000:1
  • Viewing Angle
    178°(H)/178°(V)
  • Display Colors
    10 bits
  • Response Time
    1ms GTG
  • Refresh Rate
    120Hz*
  • HDR
    Yes ( HDR10 / HLG )
  • Flicker-free
    Yes
  • HBR3
    Yes
  • Signal Input
    HDMI 2.1 x2
    Display port 1.4 (DSC) x1
    USB Type-C x1
  • Earphone Jack
    Yes
  • Microphone Jack
    N/A
  • Speaker
    15W x2 + 20W x1
  • Unique Features
    OSD Sidekick
    Aim Stabilizer
    Black Equalizer 1.0
    Dashboard
    Timer
    Counter
    Crosshair
    PiP/PbP
    Auto-Update
    KVM
    6 axis Color Control
    Space Audio
  • USB port(s)
    USB 3.0 x2
  • Power Type
    Built-in
  • AC Input Max
    325W
  • Power Saving Mode
    0.5W
  • Power Off Mode
    0.3W
  • Voltage
    AC 100V~240V
  • Tilt(angle)
    N/A
  • Swivel(angle)
    N/A
  • Pivot(angle/direction)
    N/A
  • Height Adjustment (mm)
    N/A
  • VESA Wall Mounting(mm)
    300*300
  • Kensington lock
    Yes
  • Phys. Dimension with Stand(WxHxD)
    1068.5*675.1*251.1
  • Phys. Dimension w/o stand (WxHxD)
    1068.5*611.8*43.1
  • Box Dimension (WxHxD)
    1180*760*160
  • Net Weight with stand (Esti.)
    15 kg
  • Net Weight without stand (Esti.)
    14.7kg
  • Gross Weight (Esti.)
    20.8kg
  • Accessories
    Power cable/HDMI cable/DP cable/USB cable/QSG/Warranty card
  • Note
    *HDMI2.1 supports PS5 and Xbox Series X at 4K UHD@120Hz (4:2:0)
Tags:Aorus, Pantallas, Audio y Vídeo, Gaming
Ver comentarios (1)
