Trust GXT 255 Onyx
Mostrando página 2 de 4
Especificaciones
Trust GXT 255 Onyx
ESPECIFICACIONES
General
Height of main product (in mm)
980 mm
Width of main product (in mm)
80 mm
Depth of main product (in mm)
70 mm
Total weight
1400 g
Weight of main unit
400 g
Features
Noise reduction
no
Control
Controls
master volume, microphone mute, RGB color control, sound mute
Connectivity
Connection type
wired
Connector type
USB-A
Cable length main cable
180 cm
Audio
Frequency response
30 Hz - 18000 Hz
Sound pressure level
130 dB
Microphone
Sensor type microphone
condenser
Pick-up pattern
Cardioid
Sampling rate
24bit, 96kHz
Echo cancellation
yes
Mount
Type of anti-vibration measures
shock mount, pop filter
Type of stand
table arm clamp
Compatibility
Compatible Device Types
pc, laptop
Compatible Software Platforms
Windows, Mac OS, Linux, Chrome OS
Información extra
Número de referencia: 24354
Código EAN: 8713439243543
Garantía: 2 años
Contenido del paquete:
  • Micrófono USB profesional
  • Brazo para micrófono
  • Soporte de suspensión
  • Cable USB
  • Manual del usuario
Requisitos del sistema: Puerto USB
Tags:Trust, Audio y Vídeo
