Aorus FI32U
Mostrando página 2 de 4
Especificaciones del AORUS FI32U
AORUS FI32U
  • Panel Size (diagonal)
    31.5” SS IPS
  • Display Viewing Area (HxV)
    697.3056 x 392.2344 (mm)
  • Panel Backlight/ Type
    Edge type
  • Display Surface(non-glare/ glare)
    Non-glare
  • Color Saturation
    90% DCI-P3/ 123% sRGB
  • True Resolution
    3840 x 2160 (UHD)
  • Pixel Pitch
    0.181 (H) x 0.181 (V) (mm)
  • Brightness
    350 cd/m2 (TYP)
  • Contrast Ratio
    1000 : 1 (TYP)
  • Viewing Angle
    178°(H)/178°(V)
  • Display Colors
    10 bits (8 bits + FRC)
  • Response Time
    1ms GTG / 1ms MPRT
  • Refresh Rate
    144Hz
    120Hz for Console Game*
  • HDR
    VESA Display HDR400
  • Flicker-free
    Yes
  • HBR3
    Yes
  • Signal Input
    HDMI 2.1 x2
    Display port 1.4 (DSC) x1
    USB Type-C x1
  • Earphone Jack
    Yes
  • Microphone Jack
    Yes
  • Speaker
    N/A
  • Unique Features
    OSD Sidekick
    Active Noise Cancelling (ANC) 2.0
    Aim Stabilizer Sync
    Black Equalizer 1.0
    Dashboard
    Timer
    Counter
    Crosshair
    PiP/PbP
    Auto-Update
    KVM
    RGB Fusion 2.0
    6 axis Color Control
    Smart OD
  • USB port(s)
    USB 3.0 x2
  • Power Type
    Build-in
  • AC Input Max
    120W
  • Power Saving Mode
    0.5W
  • Power Off Mode
    0.3W
  • Voltage
    AC 100-240V ~ 50/60Hz
  • Tilt(angle)
    -5°~+20°
  • Swivel(angle)
    -20°~+20°
  • Pivot(angle/direction)
    -0°~+90°
  • Height Adjustment (mm)
    130
  • VESA Wall Mounting(mm)
    100*100
  • Kensington lock
    Yes
  • Phys. Dimension with Stand(WxHxD)
    717.6*598.3*283 mm
  • Phys. Dimension w/o stand  (WxHxD)
    717.6*424.3*71.3 mm
  • Box Dimension (WxHxD)
    1000*585*198 mm
  • Net Weight with stand (Esti.)
    10.9 kg
  • Net Weight without stand (Esti.)
    7.7 kg
  • Gross Weight (Esti.)
    15.4 kg
  • Accessories
    Power cable/HDMI cable/DP cable/USB cable/Type C cable/QSG/Warranty card
  • Note
    *HDMI2.1 supports PS5 and Xbox Series X at 4K UHD@120Hz (4:2:0)
Tags:Aorus, Pantallas, Audio y Vídeo
  • Antec Vortex View 360 Review: refrigeración líquida tope de gama con pantalla rotatoria de 5"
  • ASUS TUF Gaming X870-Pro WiFi7 W Neo Review: overclock avanzado, USB4 y LAN 5 GbE
  • be quiet! Dark Perk Sym Review: ratón gaming inalámbrico ultraligero de 55 g con sensor PAW3950
  • MSI PRO MP275QPDG Review: monitor profesional con dock USB-C, webcam y Daisy Chain
  • MSI Roamii BE Pro Mesh System Review: sistema mesh Wi-Fi 7 con ciberseguridad y funciones avanzadas
  • MSI MPG 271QR QD-OLED X50 Review: 500 Hz, panel QD-OLED Gen 4 e IA para gaming extremo
  • MSI PRO DP10 14M Review: Mini PC con procesador de sobremesa para productividad profesional
  • TeamGroup NV5000 M.2 PCIe 4.0 SSD 1TB Review: económico y solvente
  • Antec P7 S Review: sobriedad, silencio y buen equipamiento de serie
  • Antec Flux M Review: máximo airflow a precio mínimo
  • MSI Modern MD272QXP Review: monitor ideal para productividad
  • Elgato Embrace Review: ergonomía avanzada y diseño elegante
