Aorus FI32Q
Mostrando página 2 de 4
Especificaciones del AORUS FI32Q
AORUS FI32Q
  • Panel Size (diagonal)
    31.5" SS IPS
  • Display Viewing Area (HxV)
    698.112 x 392.688 (mm)
  • Panel Backlight/ Type
    Edge
  • Display Surface(non-glare/ glare)
    Non-glare
  • Color Saturation
    94% DCI-P3/120% sRGB
  • True Resolution
    2‎560 x 1440 (QHD)
  • Pixel Pitch
    0.273 (H) x 0.273 (V) (mm)
  • Brightness
    350 cd/m2 (TYP)
  • Contrast Ratio
    1000 : 1 (TYP)
  • Viewing Angle
    178°(H)/178°(V)
  • Display Colors
    8 bits
  • Response Time
    1ms (MPRT) / 1ms (GTG)
  • Refresh Rate
    165Hz (OC 170Hz)
  • HDR
    VESA Display HDR400/HLG
  • Flicker-free
    Yes
  • Signal Input
    HDMI 2.0 x2, Display port 1.4 x1
  • Earphone Jack
    Yes (Audio ESS SABRE HiFi)
  • Unique Features
    OSD Sidekick
    Active Noise Cancelling (ANC) 2.0
    Aim Stabilizer Sync
    Black Equalizer 1.0
    Dashboard
    Crosshair
    Timer
    Counter
    Eagle Eye
    PiP/PbP
    Auto-Update
    KVM
    RGB Fusion 2.0
    6 axis Color Control
    Smart OD
  • Power Type
    Build-in
  • AC Input Max
    110W
  • Power Off Mode
    0.3W
  • Voltage
    AC 100V~240V
  • Tilt(angle)
    -5∘~+21∘
  • Swivel(angle)
    -20∘~+20∘
  • Pivot(angle/direction)
    +90∘
  • Height Adjustment (mm)
    130mm
  • VESA Wall Mounting(mm)
    100*100mm
  • Kensington lock
    Yes
  • Phys. Dimension with Stand(WxHxD)
    717.6*598.3*283mm
  • Phys. Dimension w/o stand  (WxHxD)
    717.6*424.3*71.3mm
  • Box Dimension (WxHxD)
    1000*585*198mm
  • Net Weight with stand (Esti.)
    10.8kg
  • Net Weight without stand (Esti.)
    7.6kg
  • Gross Weight (Esti.)
    15.2kg
  • Accessories
    Power cable/HDMI cable/DP cable/USB cable/Type C cable/QSG/Warranty card
Tags:Aorus, Pantallas, Audio y Vídeo
  • ASUS ROG Kithara Review: sonido audiófilo y drivers planares HIFIMAN para gaming
